MPM1 A10(.432) bootloader unlock
aman_rizwan00
How can I unlock bootloader of asus zenfone max pro M1, Build 432. I wasn't able to find OEM unlocking in developer options.
victor010
Zen Master III
Hi, you will not get updates via OTA if you unlock the bootloader, It's better if you keep your bootloader locked, your warranty will be void as soon as you unlock the bootloader. It does not necessarily mean that you are rooted, the bootloader can be unlocked without rooting but the processes go side by side. You will not get any benefit if you unlock bootloader and do not root.
Akasha
Rising Star I
aman.rizwan00
Do some search through Google in the XDA forums. Use Unofficial Method so that warranty is retained.
OEM Unlocking has nothing to do with this phone while unlocking bootloader in this phone. It's probably a Custom-Android Feature for other phones.
