(MaxProM1)(v432) Hotspot Usage not always counted in Data Usage
RadeonPS
Rising Star II
The amount of data used via hotspot is not reflected at all sometimes in the data usage section.
Turning mobile data off and on while still hotspot is on starts the session and is reflected in data usage.
eg: 1gb data was sent via hotspot but only 37mb is shown that too after turning mobile data on and off.
@Christine_ASUS Have you encountered the same issue?
11 REPLIES 11
RadeonPS
Rising Star II
Christine_ASUS
Hi RadeonPS
After checking, for the users who have concern about the Mobile Data Usage counting while using USB Tethering, please refer to your linking PC for data counting or downgrade your device to Android 9.
We apologize for any inconvenience caused and your valuable advice will be included in future design and optimization considerations. Thank you.
#ZB602KL Firmware Spot
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
I didn't use USB tethering much, used hotspot mostly which has this issue as far as i know. Not a major one to downgrade OS though.
ASUS_Bot
Rising Star II
