09-26-2020 08:33 AM
09-30-2020 06:44 AM
dibyarupprk2011Have you tried backup and wipe data/cache via recovery menu? If not,then doing so there is a chance that it may not happen again.https://zentalk.asus.com/en/discussion/comment/120328#Comment_120328
See this wallpaper turning black is there from very beginning of beta updates and it comes randomly when you open an app and go to home with gesture asap!!
09-30-2020 08:36 PM
AnanduDid many times!https://zentalk.asus.com/en/discussion/comment/120332#Comment_120332
09-30-2020 08:38 PM
Christine_ASUS@Christine_ASUS when i switched from rear camera to front camera... And while i using flash light from rear camera, when i click a image from rear camera the flash was glows at that time... But in front facing camera the flash was glowing continuously while i am not clicking an image from front camera...Thank you for your asking. As Anandu mentioned before, most of your issues are normal behavior of Android 10 AOSP system. I didn't encounter the same situation of Screen Brightness, please perform the Factory Reset first. For 9. Camera App:- Photo Clicking while from Front Camera, can you elaborate more about your situation and process ? Because the video is not that clear.
How frequent do you get wallpaper turning black? I tested my device yet I didn't encounter the same situation.
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
2. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the situation persists, please let me know.
09-30-2020 08:39 PM
dibyarupprk2011Bro that was not wallpaper black... That was app drawer problemhttps://zentalk.asus.com/en/discussion/comment/120328#Comment_120328
09-30-2020 08:40 PM
jefenyaarabuuni@gmail.comIt was replaced by Google Fileshttps://zentalk.asus.com/en/discussion/36556/max-pro-m1-beta-4-432-major-minor-bugs
Also, I didn't find the default File Manager Application
