LOW CALL VOLUME IN EARPIECE IN ASUS ZENFONE MAX PRO M2
boo_boopesh
Very low call volume in asus zenfone max pro m2 since updated to android 9
15 REPLIES 15
clinta16
fakhrulsojib
Please someone give any type of solution in details. The on call mic volume killing me. I have to put the earphone mic fully on my lip for the other person to hear me!
I used app from play store to check and I guessed it right, while mic mode was on 'Direct' and I recorded from usual earohone mic distance, then the sound was, well, dirrect and clear. But when I recorded in the same condition in the mode 'Communication', then I barely can hear me. Now after this test, I am sure the problem is in the feature 'microphone noice cancellation' for calls only. So as I identified the issue, is it impossible to fix? Can I totally disable the function 'noice cancellation' on my device? Please help. I am in desperate need of a fix during this covid pandemic as many many important meetings are happening online.
Mic is loud enough on the phone call app though!!!
But very low on any online call like messenger call / whatsapp call / discord call / google meet call / zoom call. But if I record on messenger or whatsapp, it sounds alright. I repeat, recorded general sound is OKAY but not when on call. Tested same earphone on same apps from an old samsung phone too. No problem found there at all! Sounded clear while using samsung during messenger call / whatsapp call / discord call / google meet call / zoom call. So don’t say it's mic's fault. It isn’t. It is software handling problem as far as I can understand. Please show me a way fast.
Same case here. The mic volume is very low when using Messenger voice call. But the volume is okay when using the native phone call app. It's frustating
