07-20-2020 04:58 AM - last edited on 01-16-2024 12:54 AM by ZenBot
Admin【Version】
16.2017.2007.094
【Model Name】
ZenFone Max Pro(M2) ZB630KL
【Release Date】
2020/07/20
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Updated Android security patch
- Fixed SIM card name editing issue
[200720] ZenFone Max Pro(M2) ZB630KL_IN_16.2017.2007.094
AdminIf you have received the update please share the experience and battery life with this update.【Version】
16.2017.2007.084
【Model Name】
ZenFone Max Pro (M1) ZB602KL
【Release Date】
2020/07/20
【Release Note】
[200709] ZenFone Max Pro (M1) ZB602KL_WW_16.2017.2007.084
08-10-2020 05:17 AM
08-14-2020 06:12 AM
PRSPLEASE HELP! My phone's battery is also draining very fast. Just as after I downloaded July update for my phone. Now I have to turn on its battery saver always, or I'll need a charger all the time.After this update
1. my mobile automatically unlocked by itself
2. Battery draining too fast
3. Even after plugging earphone I got voice from both speaker and erphone
08-14-2020 06:15 AM
jayeshkedarmailPLEASE HELP! My phone's battery also TAKES TIME TO FULLY CHARGE NOW and DRAINS VERY FAST. Just as after I downloaded July update for my phone. Now I have to turn on its battery saver always, or I'll need a charger all the time.With the july security patch i lost my fast charging its taking more time to charge then usual
08-14-2020 06:44 AM
veeharish2005PLEASE HELP!July security patch for asus zenfone max pro m1/M2 has been released.
https://zentalk.asus.com/en/discussion/32172/200720-zenfone-max-pro-m2-zb630kl-in-16-2017-2007-094
https://zentalk.asus.com/en/discussion/32167/200709-zenfone-max-pro-m1-zb602kl-ww-16-2017-2007-084
If you have encountered a bug while using, please explain the issue clearly in the comments so the developer's can find and fix those bugs.
July security patch for asus zenfone max pro m1/m2 released
08-14-2020 08:11 AM
ajmohammad35Same with me bro , it is going 100 to 0 in less than three hours, ASUS ppl told me to do some procedure but they were all useless. They are now telling to go to Service Centre.PLEASE HELP!
Been with the update for about two weeks now. My phone TAKES TIME TO BE FULLY CHARGED. Its BATTERY DRAINS VERY FAST even when not in use.
I hope a fix will be available soon. 😞
