I have downgraded my asus to build 059 and after that i can't receive any updates pla help me
rautchampak62
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
4 REPLIES 4
Christine_ASUS
Community Legend II
Hi rautchampak62
Thank you for your asking. Are you Max Pro M1 ZB602KL? If so, the downgrade file on our website "MaxProM1_downgrade_to_9" will bring your device to WW-16.2017.1912.060. Please refer to the following steps below as Android 10 to Android 9 guide
1. Download "Version MaxProM1_downgrade_to_9" and then put the image file into the root directory of the MicroSD card.
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
2. Insert MicroSD card into phone and then power off the device.
3. Long press with "Power" key and "Volume Down" key together and stop after feel the vibration to enter Recovery Mode
4. Use "Volume Down/Up" key and press "Power" key to choose "Apply update from external storage"
5. Select the downgrade file
6. When the updating process is done, Choose "Wipe data/factory reset" and tap"Yes" to perform the master clear.
7. "Wipe cache partition" > "Yes"
8. "Reboot system now"
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
veeharish2005
Zen Master I
Manually download the .60 update from asus website and place it in the root directory of your phone storage and restart
There will be a notification telling update file detected. Click on the notification
There will be a pop up showing the update file select yes .
The update will start to install
rautchampak62
Thank you so much i have upgraded my device to latest 082 version 😊😊😊😊
n_bhargavsai200
Should @rautchampak62 do the same process for future updates???
