Hugh battery drain on ideal time after 0.82 update
a_m_plabon
Model Name: Max Pro M1
Firmware Version: .082
Rooted or not: Not
Frequency of Occurrence:
12 REPLIES 12
Rameez221
I am facing the same problem
ZT-38a224a4
i am facing the same problem q
Christine_ASUS
Community Legend II
Hi friends,
Kindly refer to the guide above, try on all the steps I gave. If the situation remain the same, please provide me the screenshots as requested. Thank you.
a_m_plabon
Christine_ASUS
Hi a.m.plabon
Thank you for your asking. I came up some home troubleshooting tips below for you to try on
1. Enter "Safe Mode" and leave a 80%-100% phone in sleep(idle) mode in a night, and provide me the screenshot of
①Setting>Battery
②Setting>Battery>3 dots on the top"Show app usage"
If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
2. If the issue remain the same in "Safe Mode", please try "the Factory Reset"
Settings>System>Reset options>Factory data reset
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
3. How old is your battery?
Dear Mod,
1. As per your advice i put my phone in safe mode and situation is same. Picture attached.
2. I don't want to fatory reset.
3. My phone age is only 1 year 10 months
Christine_ASUS
Community Legend II
Hi a.m.plabon
Thank you for your reply. I will test my MPM1 with V082 in the same scenario tonight, and check if your battery performance is normal. Ciao.
