08-30-2020
02:59 AM
- last edited on
01-16-2024
12:51 AM
by
ZenBot
08-30-2020 04:21 AM
AsusYouzrI m on 084 now...any stable update of Android 10 coming soon or not? ..in a month maybePlease tell us some basic information before asking for help:
- Model Name:601kl
- Firmware Version:084pie
- Rooted or not: not rooted
- APP Name & APP Version (If your issue relates to the app): update to 429 betaA10
I m on 084 now...any stable update of Android 10 coming soon or not? If not then how will i do upgrade to A10 beta 429 ?
If i update to a10 beta 429, are there any major bug i have to face?
Gpay and other banking apps are working fine in A10 beta 429 ??
Widevine is L1 or L3 in Android beta 429??
I am now on 084 pie and widevine is L1.
Any Android 10 Beta 429 user plz confirm me about these questions.
How to update from 084 to 429? Widevine L1 in 429?
08-30-2020 06:29 AM
AnanduBro i don't know about 084 to 429 beta... But i can say that... If you installed 1st beta update i.e 407... Then you will no longer support with Widewine L1... It's L3... And you downgrade or upgrade it should be only L3 support...https://zentalk.asus.com/en/discussion/34420/how-to-update-from-084-to-429-widevine-l1-in-429
If not then how will i do upgrade to A10 beta 429 ?., Go to firmware page ans find 429 and do read description and backup
If i update to a10 beta 429, are there any major bug i have to face?.... Fingerprint problem mentioned in 429 description. Before updating remove pins, fingerprints. After updating wipe data, cache . Sound bass absent and solved through adb.
Gpay and other banking apps are working fine in A10 beta 429 ??...yes
Widevine is L1 or L3 in Android beta 429??..L1
