How to update Asus zenFone max pro M1 to android 10
Bhanu_Prakash
How to update Asus zenFone max pro M1 to android 10. Mt current version is android 9 and i didn;t get android 10 update.
8 REPLIES 8
nidhin3
Zen Master I
Bhanu Prakash
You need to download the Android 10 beta file for max pro M1 from Asus Website. You did not get it automatically because the current Android 10 build released is beta. You will receive the update once Asus releases the stable version.
If you are okay with Android 9, I Suggest you Keep using the Same because as per the latest leak Stable Android 10 will come soon for Max pro M1.
Snehashis
And what about max pro m2?
anand_vijay350
Almost 1year is going to be over still asus giving beta version 😁 developer team is shit.
Christine_ASUS
Community Legend II
Hi friends
To update Android 10 beta version, please first update your firmware to the latest version of Android 9, then visit our website to download the firmware file into the root directory, aka the outermost place, of the internal storage. Reboot. Then tap the system update notification for manual update.
# MPM1 Firmware Download Spot
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
# MPM2 Firmware Download Spot
https://www.asus.com/Phone/ZenFone-Max-Pro-M2/HelpDesk_BIOS/
#Update Guide
https://www.asus.com/support/FAQ/1009748/
