How to remove reverse charging pop-up , charging isssue
ishaan_1117
Model Name:Asus Zenfone max m1 pro
Firmware Version:X00TD
Rooted or not:not
Frequency of Occurrence:
miltrix
asus phone m2 max pro. last update ww_phone-16.2017.2011.105-20210108. popup window occur few times in a day
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Check your phone for the latest software version.
2. Clear system cache.
3. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode.
4. If still you face the issue factory reset your phone after taking a full backup:  https://www.asus.com/support/FAQ/1006346/
