How to disable emergency call power button
Dear sir Asus m2 pro mex my issue power button emergency call how to disable please help
Falcon_ASUS
sikandar958khan
@sikandar958khan
Would you please tell me in what operation did you encounter the problem?
Does your phone's power button get stuck?
If it is caused by the power button, It may be recommended to send for repair to adjust the power button.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
Shahzad07
1. Go to Settings->Apps
2. Show System Apps
3. Disable that f**king ZenUI Safeguard.
Worked for me...
