Home Screen Rotation & App Pop-up Menu Problem(PIE)
billychen105
ZF Model: ZB631KL
RAM: 6G
Firmware/APP Version: 16.2017.1906.067-20190703
Frequency of Occurrence: Every time
Rooted: No
APP Name: -
[HELP] This happened when I upgraded to pie.
  • I have deactivated the "allow home screen rotation" feature on home settings but the home screen rotation button still appears next to the recent apps menu button and that really annoys me, how do I get rid of it? ( restarting the phone doesn't solve the problem + I don't want to try factory reset )
  • This is my second problem, when I want to Uninstall or to see application info I usually just press and hold the application and a pop-up menu will appear, but after upgrading to pie it can't be done anymore, but after the phone is restarted it can be done but for a while then it can't work anymore (the pop-up menu doesn't appear again until I restart my phone again)
I think this is a bug, and I need it fixed in the next update, Can the Asus or other Asus Zenfone Max Pro M2 users tell me something?
lims
you can try this after update
billychen105
LIMS posted on 2019/8/3 22:01 you can try this after update
I tried and it didn't solve the problem
