GCAM NOT WORKING AFTER ANDROID 10 UPDATE ON MAX PRO M1
deepsaharoy7766
Model Name:ZB601KL
Firmware Version:429
Rooted or not:Not Rooted
Frequency of Occurrence: Everytime
APP Name & APP Version (If your issue relates to the app): Google Camera version 7.0
Ever since i updated to android 10 the Google camera stopped working,it was working quiet nicely on 9 pie but i updated to android 10 after restoring ..and then G.cam not working anymore. I tried restoring ..but still not working at all. I tried every version of GCAM..stil not working ,, My camera2api is enabled
17 REPLIES 17
AsusYouzr
Rising Star II
Which Gcam version is working fine in Android 9 pie 087 build?
qromodynmc
Rising Star II
You should use 7.4 version while using Android 10, 7.3 and 7.2 is compatible with android 9.
deepsaharoy7766
Yachendra
https://zentalk.asus.com/en/discussion/comment/111839#Comment_111839
After factory reset did you again enabled camera2api?
If not once try to enable and check.
I did opened the camera 2api .,but nothing happened,i tried every possible way that the problem might be solved ,but it didn't worked. Dunno what i should do... never seen such issues ever.
deepsaharoy7766
AsusYouzr
GCAM. 6.3 was working fine.u may try this.
deepsaharoy7766
qromodynmc
I have done that...not working
