Fix these on Android 10 beta 438
AsusYouzr
Rising Star II
Model Name: 601kl
Firmware Version: 438
Rooted or not: not
Frequency of Occurrence: always
APP Name & APP Version (If your issue relates to the app): Android 10 beta 438
1. SOUND
2. Suggestions for customization
3. Unnecessary pre loaded google apps
4. No option for 4k video recording in camera app.
5. Give default file manager app
1- Major issue SOUND output on earphone and speaker.
Sounds like someone raise treble bar at the highest.. which outshine bass and vocals..
Sound is not increasing after 70 percent on volume bar.. no volume raising effect after 70 percent.
No equalizer is working on player apps like VLC or Musicolet. If try to adjust on equalizer, sound just start to crack like it will tear it down.
Sound level is half compared to pie .. very low output.
2 - Customization suggestions isn't going anywhere..no matter what you do.
3 - Please remove these unnecessary Google preloaded apps..or provide uninstall option to remove these completely ..for apps like Google News, files, google play music, Android auto, Google sheet,
4. There was 4k record options in pie version camera app.. 1080p 60 fps, 30fps and lots more was there. . this camera app don't have those settings.
5. Default File manager is Op and simple. . Bring that back on user interface, we can't always go to storage settings to access default file manager. Make Google files an optional , not preload it permanently.
FIX these ( if any Android 10 versions releasing next) .
6 REPLIES 6
AsusYouzr
Rising Star II
DISPLAY
(i). Colour temperature settings are missing... Cool or warm colour adjustment is not there under display settings.
(ii). By default Screen is looking warmer or reddish .. before it was ok on pie.. color settings are missing so can't get vivid screen.
VIBRATION
(i) vibration intensity is too high..
Unlocking with Fingerprint vibrates too much.
(ii) haptic feedback also vibrates too much.. like while typing on keyboard.. or using Navigation buttons vibrates like a call /message is coming .
THEMES
Bring accent color , icon shape settings out of developers option to normal settings so that we don't have to turn developer settings on.
victor010
Zen Master III
Hi there, we have made a note of the feedback and will share it with the relevant team.
pankajfhz
also battery draining so fast
AsusYouzr
Rising Star II
4k uhd record is now appeared automatically, but 1080p, 60fps ..30fps etc is not there yet.
