03-08-2019 06:27 PM
07-14-2020 02:59 AM
Christine_ASUSwhenever i restart my phone i get a notificationHi HEtches81
Thank you for your asking. The echo issue may sometimes cause by signal conditions, kindly try some stay-at-home troubleshooting tips below:
1. Update your Zenpad firmware to the latest version, does the issue remain the same?
https://www.asus.com/support/FAQ/1009748/
https://www.asus.com/us/Tablets/ASUS-ZenPad-8-0-Z380M/HelpDesk_BIOS/
2. Please try the Factory Reset
3. Does the issue appear with earphones, speaker mode, or just normal using?
Thank you for your asking. Kindly provide the information below so that we could better assist you.
1. Does the issue always happen with the receivers in all kind of models?
2. Does the issue appear in a stable Internet environment of both?
3. Does the issue only appear in earphones? If you use normal mode or speaker mode, does the phone have the same situation?
4. Original call app or 3rd party call apps?
07-14-2020 06:33 PM
07-14-2020 07:05 PM
Christine_ASUSHi Christine_Asus,Hi HEtches81
07-14-2020 08:16 PM
08-13-2020 09:10 AM
mahato.sanjaySometimes it happens on Asus zenfone max pro M1. Toggle call audio option to loudspeaker/headphones/bluetooth audio while on call for short moment of time on dialer app/video caller app. It will solve the echo issue. I guess there is issues with audio profile configuration in asus device tree xml files.
Callers listen to echo while video calling. The problem is gone when I use headphone. Kindly sort this out. Asus zenfone max pro m1
Model = Asus_X00TD
Callers oncomplain about echo while calling.
