Buggy Location in notification bar
nimishk246
Even when you tap on location on pulling down the notification bar with no notifications the location icon remains same whether you have switched location on or off. Another thing is on using vpn the key icon that appears on the above notification bar pushes other icon to the right side making network icon cutout due to the notch.
ServiceH_ASUS
Hi nimishk246 What's your phone’s firmware version (Settings > About > Software information > Build number) Do you mean the location remain didn't change when you tap the icon in notification bar ? Please kindly the screenshots of second problem, thank you {:11_297:}
