Audio output Feedback for max pro m2-(434)
pankajfhz
Dear Asus, (please fix it down... in next update)
1- Max pro m2 audio output is very worst in 434 beta version..There is no base in it both speaker and earphone.
While the both frimware (97/101 pie) is many times better.... Not as good/loud as oreo But the best to hear.
Other than that everything is fine so far..
10 REPLIES 10
kingpubg4477
No bass in headphone and poor volume in 434 update
jithinlal14_jl
A guy on the previous beta got Bass issue fixed after adb uninstalling of icepower (adb shell pm uninstall -k --user 0 dk.icepower.icesound ).
Try it out
kingpubg4477
jithinlal14.jl
Try it out
Can you try it uninstall icepower
Abhirup
kingpubg4477
https://zentalk.asus.com/en/discussion/comment/142266#Comment_142266
I have tried this and the sound is clear and loud with base. Try it.
