Asus Zenfone max pro m2 chrome and Gmail crash
Jer
Model Name: Asus Zenfone max pro m2
Firmware Version:Newest Android 9
Rooted or not:No
Frequency of Occurrence:Always
APP Name & APP Version (If your issue relates to the app):Chrome, Gmail
I don't know why, but my chrome and Gmail always crash. Everytime I want to search or check my email, these two apps always crashed! I alr do force stop and clearing cache, but it all didn't work! Please help me if you know how to solve this problem. Now I use mozila Firefox because i cant use my chrome.
~UPDATED: FIXED~
To fix this issue, you just need to uninstall update the chrome app on setting, after that, you can update the latest version of chrome at Google play store! It's stable and this bug is fixed!
Thx to all of your replies guys!
59 REPLIES 59
Christine_ASUS
Community Legend II
Hi all
Sincerely apologize for any inconvenience caused. Kindly provide 3 main information below so that we could better assist you.
1. Model Name: Settings>System>About phone
Refer to the link below to check the model name by model no. in the link
https://www.asus.com/support/FAQ/1014441/
2. Your current firmware version
Settings >System>About Phone>Build Number
3. Version of Google/Chrome/Gamil
Settings>Apps & notifications>See all>App info>Google/Chrome/Gamil>Advanced>version no. at the bottom
=====Recap below====
1. Model Name:
2. Firmware Version:
3. Google Version:
Chrome Version
Gmail Version
4. Other relative issues:
I will forward the information above to the relevant department. If there is any other relative issues, please also let me know. We will keep you updated and your consideration will be very much appreciated.
Leonid
It work for me. Just disable then enable chrome app. Problem fixed
dbss206
Christine_ASUS
Hi all
1. Model Name:
3. Google Version:
Chrome Version
Gmail Version
Problem has been solved 🙂
There was a bug in Google Chrome new version. It was not working at all.
Just uninstall the updates of Chrome. Reinstall the update of the same.
Google have rolled back the update to an earlier stable version 🙂
gblando8
Sorry I'm on Android 9 and M1 and Gmail, protonmail, Chrome and few other apps crash on opening.
Firefox and brave work, all mail app crash.
I rolled back Gmail but still crash
Jer
gblando8
Uninstall chrome updates on setting, then update the chrome at Google play store. You don't need to roll back other apps, just need to roll back the chrome.
