ASUS ZENFONE MAX PRO M2 ANDROID 10 ( STABLE / DEVELOPER VERSION) Bugs
BANIK_AJAY
i was found Android 10 STABLE / DEVELOPER VERSION Same Bugs .
1. Customies your ZB630KL It is showing. Even I try all customized.
2. The search button was not fixed when I scroll down and scroll up then search button was moved.
3.The sound was not fixed. When I try to full sound. The sound was not good but when I try to sound medium then I can't even hear. And also my headphones sound was not good it seems like the sound was bold it not soft and it too irritating. that bcz i can't even play game bcz of sound . that foot step was not clear.
4. Again Corner problem. corner was not round. fix this bugs as soon as possible.
10 REPLIES 10
Y_ASUS
Zen Master I
Rameez221
Enable Asus video call in Android 10 stable
Hi Rameez221,
Sorry, video call is not supported on ZB601KL/ZB630KL.  We suggest that you could use "Google Duo" or other third party apps to video call.
