asus zenfone max pro m2 android 10 issue
JERIN_M_JACOB
max pro m2 A10 update broblems
1 battery drain
2 cannot use low brightness in night
3 in google photo cannot use to view in mx player. its is slow. so times it hang
4 google file manager is slow to move data
5 ringing volume ,message tune ,alarm have decreasr the sound
Y_ASUS
Zen Master I
Hi JERIN M JACOB,
1 battery drain:
Is the battery drain problem appearing in use or sleep mode?
 To monitor the battery usage, please go to Settings>>Battery>>More>>Battery usage, and stop or reinstall the high battery usage apps.
These are our suggestions to improve the battery drain problem: https://www.asus.com/IN/support/FAQ/1041741
 These are our tips to maintain a healthy battery using habit: https://www.asus.com/in/support/FAQ/1009546
If your phone is over one year of use, you may go to service center to check the battery health (life cycle remain), and check if replacing a new battery is needed.
Could you describe in more details?
Do you mean photos taken on this phone cannot be viewed in MX player?
Please try reinstalling this app. If it still appears, please tell us the app version. Does this appear to every photo?
Please try clearing cache & data of this app.
If the problem still appears, please tell us the app version and show us a short video.
Do you mean the volume has become lower? Or do you mean sound quality?
What's your volume level? Is it lower compared to Android Pie or which version?
Sukul
ZenFon Max Pro M2 Android 10 update Nahi Mila .
