06-12-2020 09:21 PM - last edited on 01-16-2024 01:06 AM by ZenBot
06-15-2020 01:51 AM
06-15-2020 02:33 AM
vssiva100Asus set up minimum brightness level a bit higher in Pie than Oreo (In Oreo it was the lowest which is 1 and on Pie it's on 5 which is far away from the lowest, Same I experienced with the beta 10.In android 9 the minimum brightness level is not minimum. In android 8 the minimum brightness level is minimum which means in night time i was able to use mobile in android 8 but not in android 9 because brightness is not minimum (adaptive brightness is OFF only) . Help me in solving this issue .
Asus zenfone max pro m1 Brightness in android 9
06-15-2020 05:46 AM
victor2020082 broHi there, kindly let us know which firmware version your device is on. We have made a note of the feedback and will share it with the relevant team.
