Asus Zenfone Max Pro M1 | Android 10 | Our demand
zamakiyakishan
Rising Star II
1. Enable Wifi Calling Features
2. Enable Fast Charging Features
3. Enable Camera 2 Api
4. Increase Ram Performance
5. Remove Extra App
6. Add Vedio / Audio Recording
7. Add Native Video Calling
8. (Increase Network) Apn List [Many time we not get proper speed on same network compare to other devices].
9. In Android 10 Developer Update In Background gallery app is running stop them.
10. Increase battery Optimization
11. Many times on more usage screen star laging stop response on tuch solve this issue.
12 . Improve Sound Output Quality
88 REPLIES 88
zamakiyakishan
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/comment/87911#Comment_87911
Those apps are Google's apps and no company can remove those apps.
The Google Play music app and Google phone app is supposed to give you the notification
And you also don't want the Google Play Store then how will you download any app . The Google Play Store is trying to download some Google apps which is not in your phone.
So if you want to complain about Google apps , you can always go to Google Play Store and leave an review for those apps.
Hello here where I mentioned I not Want Google Play Store.
veeharish2005
Zen Master I
zamakiyakishan
https://zentalk.asus.com/en/discussion/comment/88007#Comment_88007
Then why did you put a screenshot of Google play store .
zamakiyakishan
https://zentalk.asus.com/en/discussion/comment/88167#Comment_88167
See Real me , Mi device which not come with these apps
My old lg phone which is on android 8 and nokia 6.1plus and nokia 8.1 always had these apps pre installed.
And also another reason why those apps are pre installed are because those apps are default apps. Asus advertised this phone to have no bloatware. so they will not install their apps.
Eg : if you have no music player apps and you want to listen to some downloaded songs. If you select a downloaded song, it will directly play from play music.
That is why those apps are pre installed so users can do basic things without downloading any apps.
If you want you can always disable those apps.
zamakiyakishan
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/comment/88195#Comment_88195
https://zentalk.asus.com/en/discussion/comment/88192#Comment_88192
This is not nokia ok, And see in last screen shot I said about 4 useless apps not about G-Store not make your own meaning Ok.
svpraveen003
Since this is going to be final software update, Is it possible to give us Asus launcher option so that we can customize Max Pro M1 with customized themes, icons, text styles,etc ?
Call recording
auto brightness slider in quick settings
Quick charging support
Enabling Google search bar at bottom of the app drawer
Dark mode support across the devices
June-2020 security update and if possible security updates til end of 2020
veeharish2005
Zen Master I
zamakiyakishan
https://zentalk.asus.com/en/discussion/comment/88214#Comment_88214
I just said that because most phone's come's pre installed with these apps so it is not asus's fault
And about those 4 useless apps
Google sheets : 500 million downloads
Google docs : 500 million downloads
Google slides : 500 million downloads
Google play music : 5 billion downloads
So there are a lot of people who use these apps. So you can not call them useless.
If you want you can check the downloads in Google play store
