Asus Zenfone Max Pro M1 | Android 10 | Our demand
zamakiyakishan
Rising Star II
1. Enable Wifi Calling Features
2. Enable Fast Charging Features
3. Enable Camera 2 Api
4. Increase Ram Performance
5. Remove Extra App
6. Add Vedio / Audio Recording
7. Add Native Video Calling
8. (Increase Network) Apn List [Many time we not get proper speed on same network compare to other devices].
9. In Android 10 Developer Update In Background gallery app is running stop them.
10. Increase battery Optimization
11. Many times on more usage screen star laging stop response on tuch solve this issue.
12 . Improve Sound Output Quality
88 REPLIES 88
nayanjyoti699
Buying asus is a big mistake of my life......... I'm not gonna recommend anyone to buy asus smartphones......I wasted my money..........
Y_ASUS
Zen Master I
zamakiyakishan
5. Remove Extra App
Hi zamakiyakishan & sanketspencers001 & abhayparihar521 & karsanapallimanojreddy & abdabhijit790,
After checking with relevant teams, we don't have plans to support these features. Thanks for your understanding.
Fast charging is enabled. Is fast charging not shown on your phone when you charge?
We're checking with relevant teams about this.
We suggest that you refer to the articles below to troubleshoot the problem:
https://www.asus.com/in/support/FAQ/1011141
https://www.asus.com/IN/support/FAQ/1041741
5. Remove Extra App
Sorry, checking with relevant teams, the preloaded apps are not removable.
Please try resetting your network settings and try again. (Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile & Bluetooth)
- Please tell me your mobile network provider
- Please show me a screenshot of the signal strength when the problem appears.
(Settings > System > About phone > SIM status)
- Please change to another SIM card by another network provider, and check if the problem still appears.
Please also put your SIM card into other phones and check if the problem appears.
- What kind of location does this happen? Are you in any building/ on a transportation/ in the basement/indoors or outdoors?Please check in other locations as well.
Could you show us a screenshot of the message and the gallery app info?
Please tell us the app/app version/ detailed steps you performed/short video.
Could you tell us does this appear on wired earphone/bluetooth headphones/phone's speaker? Does this appear with media/call/ring/alarm sound? If media, what app/app version are you using?
13. Provide basic applications like gallery , music etc
We suggest that you use Google Photos and Google play music.
Y_ASUS
Zen Master I
gourangopal324
Asus max pro m2 ma network slow
Hi gourangopal324,
Please also tell us your firmware version: Settings > About phone > Build number.
Does this happen with WiFi or 4G?
If 4G, Please try resetting your network settings and try again. (Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile & Bluetooth)
Y_ASUS
Zen Master I
varunkumarsingh009
Updated APN list. (Network speed Is trash)
Stable/ Consistent System Wide Darkmode
Wifi calling toggle
Stable Wifi Connection
Bug Free System gestures
Is Enough for Most users
Hi varunkumarsingh009,
Is your phone ZB601KL or ZB630KL?
Dark mode is available. Which part are you referring to?
Wifi calling toggle
Which country and operator do you have?
WiFi speed will be affected by the environment and the corresponding network settings
The actual transmission speed will decrease according to the interference of the signal in the environment
Could you describe in more details about the bug and which gesture?
Y_ASUS
Zen Master I
akashbanerjee98.ab@gmail.com
Fast charging is not possible but the wifi calling feature should add for all network operator, our SD 636 soc support that.
Hi akashbanerjee98.ab@gmail.com & all,
For WiFi calling, could you tell us which country and operator? Thank you 🙂
