ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST UPDATE STARTED ROLLING OUT
Asus_mod67
Model Name:ZB601KL/ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):NEW
ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST BUILD UPDATE IS ROLLING OUT
Zentalk release notes :-
https://zentalk.asus.com/it/discussion/42096/201222-zenfone-max-pro-m1-zb602kl-ww-17-2018-2012-438#l...
PROOF:-
66 REPLIES 66
jaganjohn1612
zaidnabi123
https://zentalk.asus.com/en/discussion/comment/141837#Comment_141837
I just installed it. This is for the first time I installed any Android 10 beta version on my phone. Initial impressions Smooth UI.
Could you plz send a link...I'm on 0.87.
jaganjohn1612
kumardaksh314
OMFG! This build 438 is smooth as hell without any bugs!!! Sound is better than Pie. No low minimum brightness.
Bugs NONE!
I upgraded from Pie without factory reset. I'll write detailed review though i believe this build should be pushed as OTA to Pie.
Thank you to the developer team @Christine_ASUS 😍
Could you plz share the link for the 438 update. I'm on Android 9 0.87. The asus website does not show 438 only 434. Thanks.
Damn. Play protect is not certified. And GPay isnt work. Upgrade from latest stable Android 9. Anybody know how fix this issue?
Yachendra
Rising Star II
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142975#Comment_142975
Sadly mine is also same CTS failed, but Gpay works.
Some users have their devices certified on .438 Don't know what is issue.
Try this and check.
Remove Google account,uninstall(Restore to previous version of the play Store) and again add your account and check whether it's sorted.
Yachendra
https://zentalk.asus.com/en/discussion/comment/142982#Comment_142982
Try this and check.
Isn't work for me.
I remove Google account, stop Google Play app and remove it updates then reboot device. Then add Google account... but still not certified
