ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST UPDATE STARTED ROLLING OUT
Asus_mod67
Model Name:ZB601KL/ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):NEW
ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST BUILD UPDATE IS ROLLING OUT
Zentalk release notes :-
https://zentalk.asus.com/it/discussion/42096/201222-zenfone-max-pro-m1-zb602kl-ww-17-2018-2012-438#l...
PROOF:-
66 REPLIES 66
Kautsar
No bug fixed? Wow
Kautsar
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142053#Comment_142053
Which bug? Long battery life? Fast data speed or 3gb Ram management. LOL
Because of these noob attacks, Asus refraining to roll Android 10 update to Max Pro devices because of the day dream fantasy some noobs are riding on.
This build is stable. Though this is still beta build any bug may occur but still I didn't encounter any bug yet. Even Stable Pie had network icon bug in lockscreen though i didn't encounter that in Android 10 438.
How bout max pro m2 the changelog is only a new patch while there is bug on the headphones audio
nidhin3
Zen Master I
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142120#Comment_142120
Don't know about Pro M2, I'm using Pro M1, But both phones are identical M2 has higher clock speed.
Vro the bugs kids are discussing here are not bugs they are AOSP api & ui issues.
Yes headphones maximum sound output is little less, it doesn't increases after you push the volume slider up more than half. It's new algorithm in Android 10 but i believe the value can be set in the build by the developers of our ROM.
True:hundred_points:
Most of the users are pointing towards normal AOSP behavior and calling them 'bugs'.
nidhin3
Zen Master I
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142150#Comment_142150
I'm using 438 build since yesterday and played with almost everything thing, see my screen shots i disabled settings suggestions simply.
Screen brightness is same as Pie even the lowest level at night is pinching the eyes.
People with battery issue are having 2 year old models don't listen to them.
IMO ASUS should push the M1 438 build as OTA as a New Year gesture.
I've been using the previous Android 10 builds and honestly I never had any issues. Everything is stable for me. Even the battery performance.
I'm not an Audiophile and thus Audio has never been a major issue for me ( ya, the bass feels a bit on the lower side but not a deal breaker for me). That might not be the case with others who love music.
In short keeping audio quality aside I can say Android 10 is stable. No idea why Asus is not pushing these updates via FOTA.
zaidnabi123
kumardaksh314
How to disable it?
