Asus Zenfone Max Pro M1 Android 10 438 build
zaidnabi123
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Installed 438 build successfully on my Asus Zenfone Max Pro M1
32 REPLIES 32
mahekumr
I have found few bugs:
location settings crashing, it doesn't open at all
Default notification sound- automatically resetting to 'NewMessage sound' even after setting it as none.
Gesture navigation not working properly in other launchers.
Bad Sound quality of speakers- high on trebble no bass, not at all comparable with pie version.
black bar issue when navigation bar is hidden- when dpi is changed a black bar appears at the bottom of the navigation bar, which raises the navigation bar littile bit up and a gap appears from the bottom screen.
black bar appears at the bottom on apps.
will update about new bugs.
sujanjsr0
Rising Star II
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/145313#Comment_145313
Did anyone brother to call their own number from another mobiler to check Income call delay?
Yes i found this call delay from 1st beta ,still not solved
Yachendra
Rising Star II
