09-06-2020
04:54 AM
- last edited on
01-16-2024
12:46 AM
by
ZenBot
09-06-2020 08:54 AM
mauvin11I think asus is using a lower binned Snapdragon 660 in the asus zenfone max pro m2 to make the cost lower. If it is the case then they cannot make the cpu run at 2.2ghz since it cannot achieve higher clocks speed.The Snapdragon 660 in Max Pro M2 is not being used to its max potential (i.e 2.0 ghz) which slows down the device. Any possibility asus will remove the speed cap in upcoming major Android 10 update?
Any possibility removing the Speed Cap set on Max Pro M2 660 soc in A10?
09-07-2020 12:16 AM
09-07-2020 10:43 AM
Christine_ASUSYes. While playing Call of Duty mobile the device lags even in low graphics settingsHi mauvin11
Thank you for your asking. As you mentioned, the CPU spec of ZB630KL is Qualcomm® Snapdragon™ 660.
(Ref: https://www.asus.com/in/Phone/Zenfone-Max-Pro-M2-ZB630KL/Tech-Specs/)
1. Can you tell me where do you encounter the speed issue? Any game app or any specific function?
2. Does the issue appear in Android 10 only or does the issue appear in Android 9 as well?
3. Have you run on any specific app to check the CPU speed? E,g. AnTuTu
09-07-2020 07:09 PM
