Android system webview
AJ1
Rising Star II
How to enable Android system webview & update it?
6 REPLIES 6
AJ1
Rising Star II
Christine_ASUS
Hi AJ1
Thank you for your reply.
1. Based on your screenshot, you are a Beta tester of Android System WebView. Have you signed up Beta program for any app developer? If so, please contact the app developer.
2. Have you ever rooted or unlocked your device?
3. Please check the search result of Google Play Store>Android System WebView more carefully. Sometimes, the search result will have "Android System WebView" and "Android System WebView Beta". Please tap "Android System WebView" rather than Beta version.
4. Your current firmware version
Settings>System>About Phone>Build Number
Hi Christine,
PFB inline
1. No, not ever signed except Play store Beta.
2. Not rooted or unlocked
3. I have searched many times but same results are out
4. Android 9, 0.87 latest firmware, no new update received.
Christine_ASUS
Community Legend II
Hi AJ1
Thank you for your reply. I have checked my device multiple times yet I can search both stable and beta version. Please try to enter Safe Mode for 3rd party app conflict or perform Factory Reset for further checking.
[Phone] How to Enter and Exit Safe Mode? | Official Support | ASUS Global
# How to perform Factory Reset
Settings>System>Advanced>Reset options>Erase all data(factory reset)
**Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
[Phone] How to back up the data stored in your phone ? | Official Support | ASUS Global
