Android 10 too much delayed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-03-2021 01:26 AM
already you late too much in software development department after that you not improve your updates system...🙄..
please release update ASAP!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-13-2021 09:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-14-2021 01:18 AM
nidhin3bro after few days like 15 to 20 days this update do undesired function like call drop, gcam crashing, camera app crashing, battery drain ,ram management also very poor as compared to Android 9 ...Beta 5 is a stable build bro. If you desperately need Android 10, you can definetely try beta 5 update. Its just that there is a beta in its name.
this update only fine for those users who wants to try Android 10 for few days not as long period that's why I'm shouting that provide Android 10 stable ota ASAP🙄🙄
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-14-2021 11:21 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-14-2021 03:04 PM
qromodynmcHy, can you tell me how to revert back / downgrade to pie? i've been searching many article for months but no one seems clear enough to explain it step by step. already unlocked my phone bootloader, then tried flashing pie stable rom via ADB or whatever that is.I've used beta for months and im back to 9 and i can definitely say that beta is not stable. there are many tiny details but major issue i found is low signal from both wifi and 4g.
i've been so much mad rage this past 3 months because so many bug in beta 438, camera crashing - cant disable jump to camera by power button - weird brightness control, ect. please tell me how going back to pie.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-14-2021 08:00 PM
Thank you for your asking. For the downgrade image file and perform step from our official website.
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
Please backup your device and follow the steps below as 10 to 9 downgrade steps.
1. Download "Version Android 10 downgrade to P" and then put the image file into the root directory of the MicroSD card.
2. Insert MicroSD card into phone and then power off the device.
3. Long press with "Power" key and "Volume Down" key together and stop after feel the vibration to enter Recovery Mode
4. Use "Volume Down/Up" key and press "Power" key to choose "Apply update from external storage"
5. Select the downgrade file
6. When the updating process is done, Choose "Wipe data/factory reset" and tap"Yes" to perform the master clear.
7. "Wipe cache partition" > "Yes"
8. "Reboot system now"
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
