Android 10 beta 2 bugs
bhaveshsuthar23
Model Name:asus max pro m1
Firmware Version:.424
Rooted or not:Not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Beta 2 known bugs
1. Vibration during call
2. Audio repeated while caling
3. Double take to wake up while vibrate more
4. No hd graphics in pubg
5. Not native video calling
6. Face and fingerprint lock is slow compare than stable pie
7. Ram management
8. No internal sound recording this is supported by android 10
25 REPLIES 25
veeharish2005
Zen Master I
Sanju
https://zentalk.asus.com/en/discussion/comment/77385#Comment_77385
https://www.androidpolice.com/2020/04/07/record-audio-android-apps/
Google added a new API in Android 10 that developers can use to capture audio playback from other apps. The API is called AudioPlaybackCapture, for which screen recording apps would ask your permission to record internal audio. Once you give it, you would be able to record internal audio.
Sorry man, I thought he was referring to it as a feature in the settings which you can use it like the screen recorder in android 11 developer preview.
BlueHunt
Zen Master I
veeharish2005
https://zentalk.asus.com/en/discussion/comment/77447#Comment_77447
Not a problem. Yeah, Android 11 preview came with that dedicated option in the settings as you said. That feature is not available in A10 but the limitation of internal audio recording to any 3rd party app which was restricted till Pie, thats been lifted in A10, and thanks to the A10 API for internal audio, 3rd party apps such as Screen Recorder apps now can record internal sounds but only if an user give permission to access it and also draw over other apps permission.
Every update of Asus have bugs no update have been given by Asus which have no bug I don't think that android 10 will be stable that will also have many bugs
Gesture navigation leaves a navigation bar
Gesture navigation doesn't support external launchers like nova launcher
021
The front camera flash is always on in automatic detection mode, the video quality is very low and it's completely dark, the Bluetooth settings aren't perfect.
