Android 10 beta 2 bugs
bhaveshsuthar23
Model Name:asus max pro m1
Firmware Version:.424
Rooted or not:Not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Beta 2 known bugs
1. Vibration during call
2. Audio repeated while caling
3. Double take to wake up while vibrate more
4. No hd graphics in pubg
5. Not native video calling
6. Face and fingerprint lock is slow compare than stable pie
7. Ram management
8. No internal sound recording this is supported by android 10
25 REPLIES 25
malekm762
Asus zanfone max pro m1 jio wifi calling support airtel wifi calling not support ?:question_mark:
BlueHunt
Zen Master I
veeharish2005
https://zentalk.asus.com/en/discussion/comment/77345#Comment_77345
Android 10 does not support internal audio recording.
How to record your Android phone's internal audioGoogle added a new API in Android 10 that developers can use to capture audio playback from other apps. The API is called AudioPlaybackCapture, for which screen recording apps would ask your permission to record internal audio. Once you give it, you would be able to record internal audio.
ZT-8bc5ea17
Rooted or not:Not
1. Audio repeated while caling
2. No hd graphics in pubg
3. Sound issue in pubg
4.No internal sound recording this is supported by android 10
ZT-5481c625
Earphone sound no bass and low sound.force dark mode on deolper settings option mobile restart later of this setting camera ui erorr and crash ples slove this.
vckanandvpp
Rising Star II
malekm762
Any device which has any of the two wifi bands 2.4 or 5 GHz , and which supports VoLte will have access to Wifi calling of any operator .Until Asus add Binary patch and the Wifi calling switch on Airtel sim we can't use it. Hardware support is there , but software support has to be given through os update
As like VoLte wifi calling need to be activated by operator and you need a software switch from vendor. Check on the Airtel sim , option in phone app settings for the switch.
We ask Asus to keep this switch in Network settings menu instead of phone app settings as it is very much confusing.but never responded by Asus..
