.084 vs .429
harshitrao56
Model Name: max pro m1
Firmware Version: .084
Rooted or not: not
Frequency of Occurrence:
Should i switch to Android beta 3 (.429 version) or remaining using my battery-sucker .084
I know pretty well that there will be no pros in .429 but can anyone list the cons of both .084 and .429, it will be really helpful
.084 has killed my battery backup amd situation remain same even after changing the battery from service centre
Help a brother out !
dibyarupprk2011
Rising Star II
harshitrao56
  1. Model Name: max pro m1
  2. Firmware Version: .084
  3. Rooted or not: not
  4. Frequency of Occurrence:
.084 vs .429
Wait till sept .. there maybe e new update
Yachendra
Rising Star II
harshitrao56
.084 vs .429
1)You can wait for next update.
2) Upgrade to 429 or downgrade to 082 or lower(not 063).
084 cons as per my observation:
1) Huge Battery drain
2) Charge time more than 4 hrs
3) notification light keeps on blinking in red after we open notification or missed calls
4) if auto batter saver activated for some % and if we keep charge more than set % or fully charged, saver will be in active only. We have to turn of manually.
5) System stability- app crashes, Quickstep stop, network fluctuations.
429 cons:
1) Google bar stays on home screen
2) 3rd party apps not installing/close automatically if installed
3) more space occupied for navigation bar
4) Font size is too big in notification status bar looks ugly
There will be more, where each user face differently.
