WiFi issue
MrAvenger
Rising Star II
Model Name: zenfone 9
Firmware Version: 2050.34
Rooted or not:no
Frequency of Occurrence: all the time
Any of you guys having WiFi connection issues with the phone.
I got it yesterday however I frequently now get WiFi connectivity. It's connected to the wireless router but can't get any data flow.. Then after a while it's works.
Then after I put it to sleep and resume the WiFi stops again.all my other wireless devices work OK
7 REPLIES 7
idm
I seem to have found out what was causing the problem in my case: after uninstalling Blokada 5 everything has been working fine, with no more WiFi issues whatsoever.
So you may want the check out any app that works through a VPN or something similar, that could be a possible source of problems. The phone itself works flawlessly with all other apps and is indeed a great buy.
MrAvenger
Rising Star II
can you please tell me how to do
WiFi log generated by the calculator app
i now have discovered my phone cant get a reserved ip address when on android 13
pequinois44
même problème avec le wifi
