RAW photos
Gingerjoa
Hi. Is it planned for an update for the camera app in the future to support raw images? It's a bit strange when you have this phone that is so camera / photo focused without the raw option that almost every low to high-end android phones has now days.
13 REPLIES 13
Gingerjoa
Actually I found it. But what is the point of hiding that setting in the MAIN SETTINGS, but only when accessing from pro mode? Why not leave it at a global level?. Another thing is that it should be possible to use regular photomode with RAW.
Danishblunt
Hall of Fame I
Gingerjoa
It gets worse, it uses the full non binned mode as well. Which is garbage for low light.
Crimis
Rising Star I
Danishblunt
https://zentalk.asus.com/en/discussion/comment/224535#Comment_224535
RAW means RAW sensor data, so of course it's non-binned. It's completely unprocessed. These files are much easier to edit in Lightroom because you have information which is removed in regular JPG files.
Crimis
Rising Star I
Gingerjoa
Where did you find the setting?
