Problem with mic during phone calls on Zenfone 9
Johnysman
I have a problem with mic during the calls. The other side is frequently complaining that the voice is crackling, robotic and in the end they usually stop hearing me completely. Is there any solution?
Android 13, FW version ww_33.0804.2060.88
7 REPLIES 7
Adam1983
I just experience the same issue today. Asus. I'm calling for your feedback and support. Tell us what to do and it is annoying
Aki_Mo
I've that same issue
Like  6-8 times per week
And im gettin angry at asus
Android 13
Not rooted
Mansi_ASUS
I have forwarded the issue to R&D, and the team requires the following information from your end-
1. Which network operator do you use?
2. When did you first notice this issue? (EX: After some FOTA update )
3. Does the issue occur during the start of the call, or in the middle of a conversation
4. Does this happen while calling through third-party apps too? (EX: Line, Whatsapp)?
Aside from the above queries, can you please share a log file, as it'll help determine what triggers the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Audio, sound recording, call audio” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue-
  1. Make a call and enable call recording.
  2. Check if the issue happened again, if yes, keep the call for a minute.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file with me via PM.
T-Mobile (happends on volte and vowifi as well)
I dont use phone calling too often, it happens every few phone calls not sure when started but ppl complained about this for long time (on previous phone evrything was perfectly so when they started compaling i tho its somthin on their side or telcom)
Usually after few minutes of conversation, one time happends after 19min of
I dont use calls but standard one, i used whatapp call 3 times and was fine but there was other problem, when whatsapp shutdown screen ( as it should) i cant unlock phone, wake up screen tho any method. So i ask friend to end call and then it back to working
There is many things i dont like at zenfon9 software but this one with calling is worst and most anoying bcus have impact on my job ( calls from co-workers and boss)
