Display and pwm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-18-2022 07:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 09:06 AM
Evolution101Auto mode in zf9 is from what I know more responsive and more aggressive. Meaning, it makes sense youd feel more uncomfortable on the zf9. I strongly suggest setting it on 60hz.https://zentalk.asus.com/en/discussion/comment/223851#Comment_223851
I only use the Auto mode just like I did with the Zenfone 8. I don't want to milden the symptoms but rather eliminate the cause so if notebookcheck publish their coming review of Zenfone 9 from which can be concluded that the pwm value is worse than the previous model, I will return this and buy a new Zenfone 8 again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 09:11 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 09:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 09:21 AM
"The display backlight flickers at 495 Hz (Likely utilizing PWM) Flickering detected at a brightness setting of 45 % and below. There should be no flickering or PWM above this brightness setting.
The frequency of 495 Hz is relatively high, so most users sensitive to PWM should not notice any flickering. However, there are reports that some users are still sensitive to PWM at 500 Hz and above, so be aware.
In comparison: 52 % of all tested devices do not use PWM to dim the display. If PWM was detected, an average of 19947 (minimum: 5 - maximum: 3846000) Hz was measured."
for the zenfone 8, is it really an issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 09:30 AM
NisseWe're discussing the Zenfone 9 with regards to possible bad pwm values in comparison with the Zenfone 8 which is very good for people sensitive to pwm.From notebootreview
