Display and pwm
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-18-2022 07:45 AM
Is the display identical to the Zenfone 8 hence the pwm value should be the same?
22 REPLIES 22
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 07:49 AM
its the same panel but doesnt mean its the same pwm value. It's likely but not guranteed
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 07:52 AM
I feel the screen gives me more reactions than the Zenfone 8 did. I'm sensitive to pwm and found the Zenfone 8 to be very mild in that sense.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 08:07 AM
Evolution101Do you notice a difference between 60hz and 120hz? many have complained that the PWM issues are only above 60hz.I feel the screen gives me more reactions than the Zenfone 8 did. I'm sensitive to pwm and found the Zenfone 8 to be very mild in that sense.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-18-2022 08:17 AM
DanishbluntI only use the Auto mode just like I did with the Zenfone 8. I don't want to milden the symptoms but rather eliminate the cause so if notebookcheck publish their coming review of Zenfone 9 from which can be concluded that the pwm value is worse than the previous model, I will return this and buy a new Zenfone 8 again.https://zentalk.asus.com/en/discussion/comment/223850#Comment_223850
