Can you fixing problem for camera?
hamid_Safarizad
Model Name: Zenfone 9
Firmware Version: 32.2030.2030.26
Rooted or not: No
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): MotionCam
Hi, I tested MotionCam and there was an issue with raw video capture when using Camera 3 (ID 3 from cam the API) and the output was broken what seems to be a raw stream issue.
Can you fix that?
10 REPLIES 10
Danishblunt
Hall of Fame I
mickey10021
https://zentalk.asus.com/en/discussion/comment/228238#Comment_228238
Zenfone 6, 7 and 8 all working fine with full res mode without issue.
The Asus app only use a single frame for capture while MotionCam use multiple frames. The issue was the continuous raw stream not working properly
I am aware, motioncam brackets the images to a video file per frame which is extremely demanding, it works much like sonys HDR recording. However I don't think its an ASUS issue but a bandwidth issue, the reason why I believe that is because ID 1 works fine which is the same lens as 3, only difference is that the ID 1 mode uses physical pixel binning to make smaller images.
Have you compared the size of the ZF9 to 8,7,6? I am aware that in sheer resolution the 64MP lenses are larger, however I'd argue that due to the physically larger 50MP lens it should be able to capture more information and tehrefor the output should be notably larger in filesize.
When you take a raw image, how do do file sizes compare?
Danishblunt
Hall of Fame I
Aight so I talked with the dev of motioncamera and did some research to confirm his suspicion. Camera2API for 50mp mode is borked.
So yeah, not bandwidth related etc. actually just API being broken.
@Mattias_ASUS Camera2API is broken for 50mp mode, let the devs know.
Mattias_ASUS
Danishblunt
Thanks for the info, will let them know
hamid_Safarizad
hopefully devs fix it. Thanks
Mattias_ASUS
Hello!
I just got a reply from R&D and I got some new information.
The 50MP function is not supported in 3rd party apps
