Bluerooth keeps disconecting for a few seconds when phone is idleing for few min.
guyleegal
Zenphone 9 built nu. 33.0804.2060.113 The Bluetooth keeps turning off for a few sec. and then turns on again when the phone is not in use for a few min, I know about the issue because my smartwatch warned me it was disconnecting from my cellphone. it happens 5 minutes after the phone is idling and keeps happening every few min.
I tried to factory reset, but it didn't help
Mansi_ASUS
Hey,
Can you please share a Bluetooth log?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Bluetooth”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
ZenBot
Community Manager
Community Manager
