Android 9 Pie ROM for Zenfone Max Plus M1?
rachin99
Anyone knows where I can get the WW-16.02.1905.435 ROM for the Zenfone Max Plus ZB570TL? It was only ever available for Indian users but it's no longer available on Asus' website. I also couldn't find any other sources that weren't taken down or expired.
Falcon_ASUS
@rachin99
We would like to inform you that we no longer provide previous firmware versions or downgraded software packages on ASUS official website. This is to ensure that the security updates on your phone remain up-to-date with the latest firmware versions. We appreciate your understanding and patience. If you have any question or need assistance, please feel free to visit our service center or call the service hot line, we will do our best to provide help for your questions.
Please confirm if your phone's firmware is used across different regions.
If not, please refer to the following method to update the firmware.
Tap "Check Update" in "Settings" -> "System update" to check if the firmware is the latest version.
Note: During the update process, please charge your phone with the AC adaptor or make sure the phone has at least 15% battery power level.
However, if you are unable to update, it is advisable to visit a repair center for further verification.
