Model Name: Zenfone 9
Firmware Version: WW_32.2040.2040.28
Rooted or not: not rooted
Frequency of Occurrence: always
APP Name & APP Version (If your issue relates to the app): Bluetooth
Hi All, I'm facing issue using the airpods pro 2 on the Zenfone 9 when i connect them then i play any audio or video only the right one is working same issue if the phone on save mode.
then I found a workaround to fix this issue I went to developers option:
from Neworking section:
I change the Bluetooth audio codec to SBC
then I change the Bluetooth audio channel mode to Mono
after that it's working fine but i have to to do it every time I connect the AirPods.
Please your support to fix the issue.
Best regards
