Zenfone 8 WiFi won't activate since Android 12
As the title says.
Since the Android 12 update (only this week for me) my brand new Zenfone 8 has stopped connecting to WiFi.
When I try to turn the WiFi on, the UI responds but basically hangs. When I go back to which ever screen the WiFi is off.
I can't get to WiFi settings either because they need to be turned on.
If I restart the phone, the WiFi connects at start up and works for about 5 minutes before turning off and being stuck 'off'.
I've only seen one other thread about this and it wasn't hugely helpful. Anyone got any clues?
Mattias_ASUS
Hello @christopherjaques !
Could you give us some more info? Which firmware is your phone running?
