Zenfone 8 Android 12 Beta, System UI stopped
boygrizell
Model Name: Zenfone 8
Firmware Version: 31.1004.0404.68
Rooted or not: Not Rooted
Frequency of Occurrence: a few times a day
APP Name & APP Version (If your issue relates to the app): different apps
After installing, having problems with System UI on a daily basis, it stops.
After closing, everything works properly, but it doesn't solve the problem.
It occurs with YouTube, Google Maps, etc.
For instance, when viewing a photo and turning the phone horizontally sometimes you see black linings occur , like the "camera-opening/hole", in the picture. Then after a few moments System UI stops.
I can't make a screenshot of the problem, because that doesn't work when System UI stops 😉
15 REPLIES 15
bizzy2000
The notification icon and the black top right corner frame are incorrectly positioned on some apps such as youtube and gallery when you rotate from portrait to landscape. Goes away when you flip back to portrait.
