Wifi speed is very slow
Hello,
On my pc I am getting 80mbps but same wifi on my mobile is giving 1 Mbps. Any solution for this?
ARP_ASUS
Community Legend II
Can you share a video by comparing the same side by side?
You can try the following things:
Change WIFI connection
Change bands to 6/9/11 and check if there are any difference
Change the WIFI connection, use an alternative WIFI and check if there is any difference
Update your firmware on your phone and also on the router
Alternate wifi works great.just this wifi is having issue.
Lord_Messi
Zen Master II
Use 2.4Hz on your wifi settings and you will be fine
