05-18-2022 05:48 AM
05-19-2022 03:09 AM
05-19-2022 06:38 AM
salmanaziz406oh really? i use Celcom. i already check my sim and plan support the volte but I can't find the setting to enable it. i thought it's because of the software. okay I'll check with the telco then. thank youui sauqi im using volte right now in malaysia with maxis simcard what are you talking about.. which carrier and plan ur using you have to check because not all telco in malaysia provide volte service. brother just google your simcard plan and check for the Volte availability. hope that helps
05-19-2022 07:51 PM
syauqisaidiVoLTE officially work only on Maxis and U Mobile.https://zentalk.asus.com/en/discussion/comment/213142#Comment_213142
05-28-2022 11:30 AM
