05-23-2021
10:35 PM
- last edited on
01-16-2024
01:47 AM
by
ZenBot
Solved! Go to Solution.
05-26-2021 02:13 AM
belegdolWe're aware that there's a daylight savings issue and will get it fixed. Short term solution is to offset your schedule by one hour.https://zentalk.asus.com/en/discussion/comment/168238#Comment_168238
I got this phone less than a week ago, it would be very strange for it to need fresh start that soon.
05-24-2021 12:18 AM
belegdolThis is same case with my Zenfone 5z. I dont know if its bug or feature i have tried many times to explain moderators about same issue & also i have submitted my device logs but developers have always ignored this issue. I dont know if Zenfone 5z will get its last update with latest security patch and bug fixes. But this is still pending and dont know if this really is a problem or a feature.There appears to be a problem with scheduled power saving. I have my phone set to go to ultra-durable between 0:00 and 7:00. While it enters the power saving mode as expected, it does not exit it. I am on firmware RKQ1.201022.002.30.11.51.44. With the previous firmware it was not possible to remove the notification, but the phone would switch back to dynamic mode.
Scheduled power saving never ends
05-24-2021 06:52 AM
05-24-2021 09:46 AM
Lawrence35Factory data reset doesnt help atleast for me with my Zenfone 5z. Issue starts again after few days of factory data reset.Have you tried to reset the factory settings? Usually, if nothing helps, there is hope in dropping.
05-24-2021 10:46 AM
Lawrence35I got this phone less than a week ago, it would be very strange for it to need fresh start that soon.Have you tried to reset the factory settings? Usually, if nothing helps, there is hope in dropping.
