Poor quality of outgoing calls (voLTE, voWiFi) on ZENFONE 8; cutting words, robotic sound
arielsajda
Rising Star II
when I call via voLTE or voWiFi and someone picks up, the call sounds good, but after a while it starts to sound very bad. When I answer (even one word), it's ok again (listening to the interlocutor) for a while, and then the same... I barely can understand words.
Other users with ZF8 has same issues.
voLTE and voWiFi - the same issue. The signal is full... T-Mobile PL, and WiFi 600Mb/s.
I'm on latest release *.89
80 REPLIES 80
arielsajda
Rising Star II
Hey, enabling voLTE and voWiFi on Orange PL network SIM card with secret code makes it work perfect. No intereferred stupid sound and loss of quality. After reboot There is a need to activate services with code in dialer again and it works since 2 days for now. I've done 3 restarts for now.
State before entering code to dialer with orange sim:
State after enetering code in dialer with Orange SIM:
HD and WIFICALLING icon available while making a call.
zaborski73
arielsajda
Podaj proszę te kody
arielsajda
Rising Star II
zaborski73
https://zentalk.asus.com/en/discussion/comment/226898#Comment_226898
*#*#3642623344#*#*
Wklejasz w dialer i zielona słuchawka. Potem w ustawieniach sieci włączasz voLTE i voWiFi. Jeśli będzie włączone to wyłącz i włącz 🙂
babol
arielsajda
I entered the code (I'm also on Orange PL - nju like you) and my settings menu looks differently than yours.
In the SIM menu from your screenshot have a setting called "Połączenia 4G" instead of "VoLTE". I have enabled both (also VoWifi setting placed elsewhere) but its doesn't work. I tried with airplane mode and wifi on and I can't call anyone.
Could you please let me know what is the software version you are using? I don't know what might be the reason for other settings namings apart from that..
arielsajda
Rising Star II
babol
Latest version *.122
