06-29-2022 01:50 AM
09-08-2022 04:52 AM
babolTry putting Orange SIM card to voLTE/voWiFi supported device. Let the services (voLTE and voWiFi) activate and then take it back to Zenfone again then try to make my "procedure".https://zentalk.asus.com/en/discussion/comment/227101#Comment_227101
I wonder if it could be connected with the fact that your other sim card is T-Mobile, which allegedly supports VoLTE. Maybe it somehow enabled VoLTE for both providers? Just guessing.
If anyone else succeeded with enabling VoLTE in Orange PL please let us know here.
09-08-2022 05:31 AM
arielsajdaYou are a genius! It works! Alright so now for anyone trying to make it work in Orange PL:https://zentalk.asus.com/en/discussion/comment/227106#Comment_227106
09-08-2022 06:30 AM
babolFantastic, I hope it will be working for now because call quality upgrade is more than noticeable! 💪https://zentalk.asus.com/en/discussion/comment/227109#Comment_227109
1. You need an orange supported VoLTE phone . Put your sim card in it and enable volte and Vowifi. Make a test call with airplane mode on to ensure it works.
2. Put your card into Zenfone, input the code *#*#3642623344#*#* into dialer
3. Enable volte Vowifi in settings and it should work. If not, disable and enable again.
It seems we just need to first enable the features on a phone that is actually certified.
Thank you once again @arielsajda !
09-08-2022 09:13 AM
babolHave you signed a petition on Orange PL site about certificating ZF8?https://zentalk.asus.com/en/discussion/comment/227109#Comment_227109
09-08-2022 09:31 AM
arielsajdaYup, that's done.https://zentalk.asus.com/en/discussion/comment/227118#Comment_227118
https://nasz.orange.pl/t5/Pomys%C5%82y/Asus-Zenfone-8-dodanie-VoLTE-oraz-VoWiFi/idc-p/327317#M13100
