Poor quality of outgoing calls (voLTE, voWiFi) on ZENFONE 8; cutting words, robotic sound
arielsajda
Rising Star II
when I call via voLTE or voWiFi and someone picks up, the call sounds good, but after a while it starts to sound very bad. When I answer (even one word), it's ok again (listening to the interlocutor) for a while, and then the same... I barely can understand words.
Other users with ZF8 has same issues.
voLTE and voWiFi - the same issue. The signal is full... T-Mobile PL, and WiFi 600Mb/s.
I'm on latest release *.89
80 REPLIES 80
babol
babol
Cyslawo
I will test this also in Orange Flex (I heard, that they dont block phonses in flex), however I'm starting to loose my patience to this phone and whole brand. Was thinking about Zenfone 9, but it will be probably Samsung or something like this.
Did you have the time to test if orange flex also blocks our uncertified ****** phone?
Cyslawo
Rising Star II
babol
https://zentalk.asus.com/en/discussion/comment/227515#Comment_227515
Flex works perfectly, and no blocking... Actually I'm in the process of moving my TMobile number to flex.
arielsajda
Rising Star II
Cyslawo
https://zentalk.asus.com/en/discussion/comment/227948#Comment_227948
A 5g flexowe działa na zenku?
Cyslawo
Rising Star II
arielsajda
https://zentalk.asus.com/en/discussion/comment/228131#Comment_228131
Nie wiem, bo to jest w tym droższym pakiecie, a ja mam najtańszy. Ale powinno, bo według flex wystarczy telefon ze wsparciem 2100mhz i właśnie droższy pakiet.
