06-29-2022 01:50 AM
09-07-2022 06:24 AM
09-07-2022 09:32 AM
arielsajdaPodaj proszę te kodyHey, enabling voLTE and voWiFi on Orange PL network SIM card with secret code makes it work perfect. No intereferred stupid sound and loss of quality. After reboot There is a need to activate services with code in dialer again and it works since 2 days for now. I've done 3 restarts for now.
State before entering code to dialer with orange sim:
State after enetering code in dialer with Orange SIM:
HD and WIFICALLING icon available while making a call.
09-07-2022 10:13 AM
zaborski73*#*#3642623344#*#*https://zentalk.asus.com/en/discussion/comment/226898#Comment_226898
09-08-2022 12:56 AM
arielsajdaHi,Hey, enabling voLTE and voWiFi on Orange PL network SIM card with secret code makes it work perfect. No intereferred stupid sound and loss of quality. After reboot There is a need to activate services with code in dialer again and it works since 2 days for now. I've done 3 restarts for now.
09-08-2022 01:10 AM
babolLatest version *.122https://zentalk.asus.com/en/discussion/comment/226898#Comment_226898
I entered the code (I'm also on Orange PL - nju like you) and my settings menu looks differently than yours.
In the SIM menu from your screenshot have a setting called "Połączenia 4G" instead of "VoLTE". I have enabled both (also VoWifi setting placed elsewhere) but its doesn't work. I tried with airplane mode and wifi on and I can't call anyone.
Could you please let me know what is the software version you are using? I don't know what might be the reason for other settings namings apart from that..
